LabWindows/CVI
detect 32 / 64 bit OS
Dear CVI users,
I've got a simple question:
I know that with the "GetWinOSVersion" si possibile to detect on which Win OS the application is running [GetWinOSVersion (&MajorVer, &MinorVer, &Build, &Platform);].
I was wondering if is there a way to detect if the OS is 32 or 64 bit.
thanks in advance.
(4,755 Views)
you could try to determine the size of an integer, it should make a difference...
(4,752 Views)
I'll make a try... but I'm afraid that the size of an integer is decided at compiler time, not at runtime...
What do you think?
(4,743 Views)
yep, you're right... if you have the full CVI version, you could use e.g. the GetNativeSystemInfo function, see here
(4,734 Views)
See:
http://msdn.microsoft.com/en-us/library/ms724429(VS.85).aspx
The code there should get you started on how to determine exactly what OS version you are running on.
Caveats: It uses Windows SDK functions and I have not personally tested it in CVI. Also, the comments below the code indicate that it has some problems. But like I said, it is a start.
Martin Fredrickson
Test Engineer
Northrop Grumman
Advanced Systems and Products
San Diego, CA 92128
(4,680 Views)
There's a slightly easier method with example code here.
Martin
Certified CVI Developer
(4,665 Views)
