‎04-23-2014 01:10 PM
I would like to build and run my CVI application as a 64 bit exe. However it uses datasockets, so I cannot. Are there any plans to support datasockets for a 64 bit application ?? If so, when ?? And if not, what are the alternatives ?? (I'm thinking replacing the datasocket connection with TCP).
‎04-28-2014 05:45 PM
Hello hjb,
Currently, the DataSockets library is only compatible with 32 applications. However, you could use LabWindows/CVI TCP support library to develop your application. This library is compatible with both versions.
Carmen C.
Hello hjb,
Carmen C.
‎04-30-2014 11:25 AM
Although you could certainly use the TCP library, I believe that the Network Variable library is a much closer approximation to what you could do with DataSocket.
