LabWindows/CVI
data from panel
How can I input on the panel be made into a file?
(3,568 Views)
Accepted by Axinia
Hi Axinia,
am I correct in understanding that you want to get the values of your user interface objects and write them to a file?
You can do this by using the GetCtrlVal command to read out the values and then use the OpenFile, WriteFile and CloseFile
commands to write your values into a file.
There are also some examples in the CVI example finder if you search the Fundamentals -> File Input and Output palette.
Hope this helps.
David
(3,548 Views)
the problem is solved
thx
(3,497 Views)
