LabWindows/CVI
currentDb error
HI friend I have one problem with currentdb metodo i need help....... it metodo work very good only with anything windowsXP so i think foult  anythink dll controler..............Lets'me code  look adjunt
Thanks very much...
(3,875 Views)
Hola,
Puedes explicar mejor el error? Cual és el código del error? Que version de LabVIEW estas utilizando? Que sistema operativo estas utilizando? Cuando el error ocurrió?
Cordiales Saludos
Luciano Borges
National Instruments Brazil
Message Edited by Lucianogob on 11-28-2008 05:28 AM
Luciano Borges
Test Development Engineer
(3,860 Views)
Luciano Borges
(3,859 Views)
Ok ola lucianog gracias por el interes .........Pero bueno pude encontrar un controlador dll necsario para este problema .....
De todas maneras uso Labview 8.6 en windows xp sp2
(3,830 Views)
Try to use the ADODB Activex, see bellow a example to connect on the Northwind.mdb.
I hope it's help.
Message Edited by Osvaldo Santos on 12-02-2008 06:43 PM
Osvaldo Santos
(3,797 Views)
