LabWindows/CVI
ctrl+tab shortcut behavior changed for editor tabs in CVI 2019?
Hi all,
I frequently use the ctrl+tab shortcut to switch editor tabs from current tab to previous one.
In CVI 2019, it doesn't seem to work any more. It just works like I continuously press the tab key without releasing the ctrl key.
It works well in CVI 2017. If I press ctrl+tab and release the all keys then the active tab is switched to the previous tab, and if I do it again the tab I just switched from is activated again. If I do it repeatedly, it cycles between the two tabs.
Now, in CVI 2019, even if I release all keys and then press the key combination again, it just changes the active tab by the Z-plane order just like I keep pressing the tab key while the ctrl key is still being pressed.
Sorry for my poor English. I hope somebody could get the point. 🙂
Thanks for reading!
(2,063 Views)
Nobody knows?
(1,416 Views)
Just noticed that new behavior minutes after I installed the 2020 evaluation.
That was one of the best features of the editor.
I hope there is a way to bring it back.
S. Eren BALCI
IMESTEK
(1,256 Views)
Me too after installing 2019. And I'm disappointed as well!
(1,253 Views)
