05-24-2020 08:42 AM
Hi all,
I frequently use the ctrl+tab shortcut to switch editor tabs from current tab to previous one.
In CVI 2019, it doesn't seem to work any more. It just works like I continuously press the tab key without releasing the ctrl key.
It works well in CVI 2017. If I press ctrl+tab and release the all keys then the active tab is switched to the previous tab, and if I do it again the tab I just switched from is activated again. If I do it repeatedly, it cycles between the two tabs.
Now, in CVI 2019, even if I release all keys and then press the key combination again, it just changes the active tab by the Z-plane order just like I keep pressing the tab key while the ctrl key is still being pressed.
Sorry for my poor English. I hope somebody could get the point. 🙂
Thanks for reading!
08-26-2021 12:21 AM
Nobody knows?
01-09-2022 11:38 AM
Just noticed that new behavior minutes after I installed the 2020 evaluation.
That was one of the best features of the editor.
I hope there is a way to bring it back.
01-09-2022 12:45 PM
Me too after installing 2019. And I'm disappointed as well!
