LabWindows/CVI
creating child panel in .uir editor
Hi -
I think I need to add a child panel to my UI. I'd put all of my control buttons/boxes on it, and then when I want to make them all disappear, I can just do so through the panel (please correct me if I'm incorrect about this).
Is there a way to create a child panel through the .uir editor? I can't find one. It'd be a lot easier than doing it through code, especially since all my controls exist already and are currently under the main panel.
Thanks.
(3,817 Views)
You can create child panels in the UI editor, too. There is actually no difference 😉 The only difference is when loading the panel where you specify a parent pamel:
    hparent = LoadPanel (0, "panels.uir", PARENT);
    g_hchild1 = LoadPanel (hparent, "panels.uir", CHILD1);
Have a look at the example "panels" provided with CVI.
I have to correct myself: there is one difference: for child panels you canset additional sttributes in the UI editor such as frame style...
(3,812 Views)
Hello mzimmers,
there is nothing special in a panel that designates it as a child or top-level panel: the childhood is given to a panel when you load it in memory, not when you design it! Specifically, if the first parameter in LoadPanel is a valid panel handle, the new panel will be a child of that panel; ir 0, the panel will be a top-level one.
Having said this, I'm not sure I understand the exact reason you want to use a child panel: if it'a just a way to show/hide controls, you can use SteCtrlAttribute (..., ..., ATTR_VISIBLE, ...); command to perform this task. If you have several controls, there are several ways to ease up the task, specifically:
  • Use an array of control IDs and iterate on all controls in a loop (see the solution proposed by DaveC in this discussion; the while discussion can be of some help to understand something on UIR file constants and how are they used)
  • Use a list of controls and SetAttributeForLists: this relies on Lists found in the Programmer's toolbox, a tool that can be of help in some situation
  • Use an array of controls (a feature introduced in CVI 2010)
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(3,808 Views)
Thank you both...helpful information, as always.
(3,793 Views)
