LabWindows/CVI
convert an array in a xml file
I try to convert an array I received from a http server in a xml file. So I will be able to handle the data with the cvixml-lib. The problem are all special signes like "<" or ">". For example the code for "<" is "&lt;". Do I have to write an own parser for all this 5 spezial characters or is there a nice function can do this for me?
I use CVI 2012.
Thanks a lot!
(3,332 Views)
Hi DRiegel,
Unfortunetely, there appears to be no such function in the CVI ADE, that's available for users.
Nelu **bleep**arasan || National Instruments
(3,316 Views)
Accepted by DRiegel
ok, the right question is: "how to convert html in xml"
that's how i did it:
hope it helps!
  while ( paSource[iAktuellePosSource] > 0 )
  // while no end of string continue with loop
    if ( paSource[iAktuellePosSource] == '&' )
    { // a new escape seq was found!
      switch ( paSource[ iAktuellePosSource + 1 ] )
        case 'l':
          // found &lt; -> replace with <
          paDestination[ iAktuellePosDes ] = '<';
          iAktuellePosSource += 4;
        break;
        case 'g':
          // found &gt; -> replace with >
          paDestination[ iAktuellePosDes ] = '>';
        break;
        case 'a':
          if ( paSource[ iAktuellePosSource + 2 ] == 'm' )
            // found &amp; -> replace with &
            paDestination[ iAktuellePosDes ] = '&';
            iAktuellePosSource += 5;
          else
            // found &apos; -> replace with '
            paDestination[ iAktuellePosDes ] = '\'';
            iAktuellePosSource += 6;
        break;
        case 'q':
          // found &qout; -> replace with "
          paDestination[ iAktuellePosDes ] = '"';
        break;
    else
      // normal sign just copy
      paDestination[ iAktuellePosDes ] = paSource[ iAktuellePosSource ];
      ++iAktuellePosSource;
    ++iAktuellePosDes;
(3,312 Views)
