LabWindows/CVI
controlling RTS on a Com port
Is there anyone who has code to control the RTS line of a com port using LW/CVI?
Jim
(3,479 Views)
In other words : What does THIS mean to you?
VI_ATTR_ASRL_RTS_STATE
Resource Classes
Serial INSTR
Attribute Information
Access Privilege Data Type Range Default
Read/Write
Global
ViInt16
VI_STATE_ASSERTED (1)
VI_STATE_UNASSERTED (0)
VI_STATE_UNKNOWN (-1)
N/A
Description
VI_ATTR_ASRL_RTS_STATE is used to manually assert or unassert the Request To Send (RTS) output signal.
When the VI_ATTR_ASRL_FLOW_CNTRL attribute is set to VI_ASRL_FLOW_RTS_CTS, this attribute is Read Only. Querying the value will return VI_STATE_UNKNOWN.
(3,473 Views)
Well,
It looks like I managed to dig far enough to find the answer. Too bad there was no easy path.
After a lot of trial and error, I found out how to use viSetAttribute(). Of course, that was after a few hours of searching for the meaning of viOpenDefaultRM() and viOpen().
If I get the time (since I wasted so much making this work) I'll post a .zip file with a good example.
NI gurus - Can you please write a 'good' online reference? Please?! Maybe include a few cross references and 'hints' along the way?
Till then ...
(3,464 Views)
Hi Jim,
I did some research to see if there was any info on controlling the RTS on a COM port in LabWindows/CVI but the only thing I could find was info for how to do it in LabVIEW. Here is that document:
http://digital.ni.com/public.nsf/websearch/1ECEFAA7AD52994986256966005356EA?OpenDocument
Hopefully we can get something similar to this for CVI soon. Thanks for the suggestion.
JenK
(3,432 Views)
