LabWindows/CVI
Reading Elements from an Array
I have a program that is sending an array to my labview vi. the size of the array is constantly changing with each new update(1 per second). As a new update is sent in, a new row is added to the array. I need to be able to keep the older elements in the array, but have only the most current row sent to a display. how can I do this?
(3,367 Views)
One additional thing: To test the file now, I'm reading files from a spreadsheet file, and want it to only display the last row.
(3,366 Views)
Hello JMorgan,
This can be accomplished by appending the new row to the current array and changing the array's index value to the new data's location.
Attached is a small example to get you started.
Matt F
(3,329 Views)
