LabWindows/CVI
communication between Labwindows and vb
I want to transfer data(an integar value) from Labwindows to visual basic.
Please tell me the ways to fulfill this requirement.
(3,618 Views)
You could use a named pipe, shared memory, or some other IPC mechanism.  Bear in mind that VB doesn't have an unsigned integer type.
Or, you could build your CVI code as a DLL and call the DLL from VB.  You can add a type library to the DLL to enhance VB support.  When you have the type library, the CVI DLL can be loaded as a resource in the VB environment.  Then use an accessor method from VB to get your int value.
Menchar
(3,592 Views)
You might also wish to use the Shared Variable Library (if you have a more recent version of LabWindows), in which case you could include a LabWindows client DLL for use from your Visual Basic program.
http://zone.ni.com/devzone/cda/tut/p/id/5484
(3,504 Views)
