From Friday, January 17th 11 PM CDT (January 18th 5 AM UTC) through Saturday, January 18th 11:30 AM CDT (January 18th 5:30 PM UTC), ni.com will undergo system upgrades that may result in temporary service interruption.
LabWindows/CVI
Can you debounce panel buttons?
I have an application that uses several panels, displayed on top of each other. Each panel has buttons.
As an example, let's say that panel A has an exit button. Panel B is displayed on top of panel A and it also has an exit button in relatively the same position.
The users are complaining that if they inadvertantly double-click, it exits panel B and exits panel A. They only intended to exit panel B.
Is there a way to easily debounce the button presses?
Thanks!
DJW
Message 1 of 12
(4,192 Views)
I see no easy solution to your problem: it's difficult to understand when the user double-clicks inadvertedly or on purpose. Supposing you can detect this situation, you could discard the click event on the button by returning 1 to the function, or you could simply rise a flag that instructs button callback to exit without doing nothing.
In situations like this I usually prompt a confirmation message with PromptPopup so that the user is required for an explicit confirmation of this action.
Message 2 of 12
(4,183 Views)
Why not just dial up (or down)  the time allowed between clicks that are considered a "double click" ?  You can do this with mouse settings from the control panel on Windows machines.
Menchar
Message 3 of 12
(4,178 Views)
Thanks for the suggestions, however, neither of them are options for me. This is a widely distributed program so I don't have control over the mouse functions. And it's been around awhile so I don't have the liberty of adding the confirmation popup. I guess I will try disabling the buttons within the event call back.
DJW
Message 4 of 12
(4,172 Views)
One rather straightforward solution would be to size the panels (or move the buttons) in such a way that the buttons did not overlap.  I realize that if you have a standardized layout, this may not be possible.  Another option would be to respond to the panel's EVENT_GOT_FOCUS event by setting a global flag that indicates your button should be disabled. Immediately after setting the flag, you can enable a timer (maybe .2 sec) whose callback does nothing but clear the flag and disable the timer.  This means that for a period of .2 seconds after your panel becomes active, the flag is set.  Your button callback now just needs to ignore EVENT_COMMIT (or better yet, swallow EVENT_LEFT_CLICK) when the flag is set.  Admittedly, this is more complicated than desirable, but the timing of the scenario makes it the only good solution I can think of.
Mert A.
Message 5 of 12
(4,149 Views)
Something like that should do the trick (tested with an InstallPopup'ed panelB :
It's not really something I'm proud of...
int CVICALLBACK QuitBCallback (int panel, int control, int event,
        void *callbackData, int eventData1, int eventData2)
int Status;
int panelGUE;
int ctrlGUE;
int ActivePanel;
    switch (event)
        case EVENT_COMMIT:
            DebugPrintf("QuitBCallback COMMIT\n");
            Delay(0.100);
            do
                Status = GetUserEvent(0, &panelGUE, &ctrlGUE);
            while (Status != 0);
            ActivePanel = GetActivePanel ();
            if (ActivePanel == panelB)
                RemovePopup(panelB);
            break;
    return 0;
Nicolas
Message 6 of 12
(4,130 Views)
The do/ while loop may be replaced by a ProcessSystemEvents.
The idea is to allow another event to fire while processing the first EVENT_COMMIT.
if (ActivePanel == panelB) is there to avoid removing panelB a second time.
Nicolas
Message 7 of 12
(4,124 Views)
It's true that there are people who after 10 years of computer usage still
cannot grasp to difference between a left click and a right click, so a
single/double click may be completely out of their reach. But personally I'd
let the problem solve itself. Maybe after they crash the program 60 or 70
times, they'll figure out the difference.
Otherwise, why do you care if they use the program at all ?!?
OK, call my an cynical elitist...
Guillaume Dargaud
http://www.gdargaud.net/
"Smith & Wesson - the original point and click interface."
Message 8 of 12
(4,077 Views)
To cynical - My users are U.S. soldiers. It is my job and my civic responsibility to support them in any way I can.
To Mert and Nicolas- Thanks for the ideas. I understand both of your implementations and will give them a try.
DJW
Message 9 of 12
(4,069 Views)
> responsibility
Then it gets frightening !!!
BTW: I wasn't serious, but I didn't have any simple fix to offer...
Guillaume Dargaud
Message 10 of 12
(4,026 Views)
