LabWindows/CVI
case insensitive search for a string
I am using strstr() to search for a substring in a string. I now want the search to be case insensitive. Are there any built in functions for this, or what do I do? How about to turn an entire string from mixed case to upper case?
(4,767 Views)
You can't have the function ignore case, but you can convert the string into all upper or lower case with functions like toupper in the ANSI-C library.
For example:
char str[10] = "Cvi Rocks"
char upperStr[10];
for (i=0;i upperStr[i] = toupper(str[i]);
upperStr[strlen(str)] = "\0";
upperStr would then contain CVI ROCKS.
Best Regards,
Chris Matthews
(4,767 Views)
hello
Check out the stricmp() function.Here is what the help states:
This function compares two NUL-terminated strings. The comparison is based upon the value of the characters in the strings. Each character is interpreted as an unsigned char.
The comparison is not case-sensitive."
Hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(4,767 Views)
Another approach is to use RegExpr_FindPatternInText() from regexpr.fp that
comes with CVI 6.0. It takes an argument (the 2nd one) that lets you specify
case-insensitivity, and the string you're searching for can be a regular
expression, for example:
x = RegExpr_FindPatternInText ("XYZ", 0, "abcxyz", -1, RegExpr_SearchForwards,
RegExpr_MatchSmallestNumChars, &mat, &pos,
&len);
"pos" returns the 0-based position of the match (i.e. 3 in this example) or -1
if no match was found.
Regular expressions are generally more flexible for text searching. If your
program controls the content of the sub-strings then they're a good solution.
However, if the sub-strings that you're searching for are supplied by another
source that may include rando
m meta-characters like *, [ or \ in them, then
uppercasing the strings as Chris suggested is a better way to go.
(4,767 Views)
Thanks. I am only using CVI 5.5, but should probably move up. I already solved this with char by char toupper from an earlier post, but thanks anyway.
(4,767 Views)
