LabWindows/CVI
cannot uninstall CVI2010 disributed program
hi,
I have run into to a problem with CVI2010 distributed installation files. I cannot uninstall the previously installed program using control panel add/remove software tool. The installed software is on the list, but when trying to uninstall it nothing happens.
I attach error.log file I get using msiexec /x /lv command. I have installed software previously from same path as I'm trying to uninstall it.
I use the same configuration file for distribution settings as I did for previous version of CVI. Uninstall worked correctly in that time.
Any hint ?
best regards,
petri
(3,514 Views)
If you're using a non-English Operating System, the reason could be this one.
See also this discussion.
Hope this helps
Vix
In claris non fit interpretatio
Using LV from 7
Using LW/CVI from 6.0
(3,511 Views)
Thanks Vix, I read your contribution in this forum to come so long as I have done so far.
We are using Swedish OS, but help in link you provided didn't help me. Same error still.
regards,
petri
(3,507 Views)
Accepted by topic author Petri
Sorry, I selected UK English by mistake and that didn't help. USA English works. I could uninstall the software. Thanks.
best regards,
petri
(3,503 Views)
