LabWindows/CVI
build output window
How to display the Build Output Window in LabWindows/CVI 2010 ? Under "Windows" Build Output is always dimmed
(5,266 Views)
Did you use the 'Clear Window' context menu...? Then it might be this bug
(5,261 Views)
Hi Wolfgang,
thanks for your answer, I didn't use the context menu "Clear Windows".
The menu item is dimmed from the beginning, see attached screen shot.
(5,241 Views)
Accepted by wishmaster
Build outpout window is automatically displayed in case of build errors. You can then hide this window and display it again with the menu function that will be consecuently enabled.
If you have not yet builded the project or if building gave no errors that menu item is grayed out.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(5,229 Views)
That simple... So 'always dimmed' meant you never had built a project... I didn't think of this possibility Smiley Surprised Well, Roberto did, fortunately Smiley Happy
...and I can partially correct Roberto Smiley Very Happy, a very rare occasion... At least of CVI2013 one can show the Build Output window even if there are no build errors...
(5,215 Views)
