LabWindows/CVI
build error "badly formed pathname" at the fist line.
"badly formed pathname",such build error point at "#include <....... >".
(4,266 Views)
Try opening any of the examples with CVI and see if they give you the same error. It may just be because it cannot find a file or something.
Also Check under the Build->Target Settings menu and see if the path to the executable you are building looks right. Be sure to check both the debug and release configuration.
Bilal Durrani
Bilal Durrani
NI
(4,266 Views)
I got this error with all CVI examples.It also happened when i try to run all the head files.
(4,266 Views)
