LabWindows/CVI
"Multiply defined symbol" link error
I need to access some controls from some modules in my application.
I have made and have attached a simple example to show you it:
These controls (checkbox controls) are defined at "Auxiliar.uir".
They have to be visible in "Panel.c".
My idea is to create an intermediary module ("Auxiliar_CTES.h") with arrays of this controls, that is included at .c modules that need it (Panel.c and Auxiliar.c).
When the project is linked, appears the following error:
Multiply defined symbol '_GENERALoptions' in modules 'Panel.c' and
'Auxiliar.c'.
Some ideas?
silmarba
(4,021 Views)
Look at the attached file: I have modified your project in order to work correctly.
The problem is that you can define a variable in a module included in more source files (and that variable is global to all those files) but you cannot assign a value to this variable in the same include file: you need to assign it in one (and one only) source file.
Try it.
Roberto
(4,021 Views)
