LabWindows/CVI
app exiting before main function ?
Hi I have an app that depends on 4 or 5 dll's it is working fine on most machine (with cvi installed).
I have made a distribution kit and installed it on a machine without cvi but the app exits immediately.
I have also tried to copy the entire bin directory containing all my dll's from my development machine with the same results.
I suspect that one dll is causing the app to exit but how can I debug this.
Execution never reaches the main function as I have placed in printf statements to track the process.
Any tips greatly appreciated.
(3,389 Views)
Hi there,
Have you tried just creating dummy programs.  Each of which only call a single DLL?
If you tried that you could maybe find the source of the problem?
Are the DLL's threadsafe?
AdamB
Applications Engineering Team Leader | National Instruments | UK & Ireland
(3,361 Views)
I solved the problem it was a dll that dpended on MSVCR71.dll
so I have to distribute this along with the MSVCR8.dll runtime now ?
Anyway I had to install visual studio to get it to tell me the problem with the missing library by using it in a dummy program.
cvi just failed with general protection fault.
(3,357 Views)
