LabWindows/CVI
Write array In excel
Hi I want to write an array in an excel table, but I don't know why it doesn't work.
My array take data from some sensors. I attach the photos. The code works but this function no
(1,933 Views)
There is nothing we can consider to try understanding what's happening: the first image shows the code that launches Excel and no more, the other is simply an array definition, so...
Post the relevant code if you want some help.
(1,908 Views)
I sent you the project File. I attach the relevant part.
This function must be repeated for all 32 controls.
Thank you Roberto
(1,898 Views)
file project
(1,897 Views)
(I Tried also with ExcelRpt_Setcellvalue)
(1,895 Views)
Accepted by johnbop
Comunque RO>berto bo visto su un'altra discussione che sei italiano in parole povere sia con il setcellvalue sia con il write data il mio array VFloat non scrive all'interno del foglio excel
(1,892 Views)
