LabWindows/CVI
With CVI2013 breakpoints work differently
In the past, I used to insert lines 'doing nothing' but allowing me to set a breakpoint. Now, with CVI2013, the following does not work anymore:
if ( expression )
// something
else
;    <- putting a breakpoint here is useless: the breakpoint is ignored
The workaround is to have something like
if ( expression )
// something
else
Delay (0.1);    <- putting a breakpoint works
Could it be that clang is 'optimizing code' even in debug mode...?
Also, setting or removing a breakpoint causes the file being recompiled - this slows down debugging enormously Smiley Frustrated
(5,120 Views)
Hi Wolfgang,
you're right. The compiler is optimizing the code even in debug mode. Maybe you could try to change the compiler optimization level to solve your problem.
What Do The LabWindows/CVI Compiler Optimization Levels Mean?
http://digital.ni.com/public.nsf/allkb/8A38D87DDA143CBC86257BB90077C217
Lars
(5,101 Views)
Hi Lars,
thanks for the input! I did play with the optimizations before (of course...Smiley Wink) and did not see a difference, not even in compilation time, unfortunately.
What I did notice is that the breakpoint may be shifted - and this is in accordance with the help saying that LabWindows/CVI moves the breakpoint to the next line that contains executable code.
Is there any good reason why the compiler should optimize code in debug mode even if release mode is set to no optimizations? The Build Options panel seems to imply no optimizations..., see below
(5,093 Views)
Accepted by Wolfgang
Hello Wolfgang,
The compiler is "optimizing" code in debug configurations in the sense that it's not generating any code for an empty statement (a single semicolon). It's not doing any other kinds of optimizations. I have filed bug report # 423474 for the issue, because as you point out it can be quite useful to be able to set a breakpoint on those empty statements.
I cannot reproduce your second problem. I can set and remove breakpoints during a debugging session as in CVI 2012. The file is not recompiled as a result and the debugging session is not restarted or aborted. I'm probably missing something. Can you post step-by-step instructions to reproduce the problem?
(FYI: When you start debugging, CVI always checks if anything in your project has to be rebuilt and the Build Output window appears. But this doesn't mean that CVI is actually rebuilding anything. It's just our way of saying "Just checking if the project is still up to date. And it is. Move along.")
Peter
(5,070 Views)
Hello Peter,
Thank you for the explanation of 'optimization'.
Personally I would not have called this behavior a bug - it's different than before (and somewhat less convenient) and thus should have been mentioned in the Release Notes, that's all. But I'll be glad to see this optimization removed!
Concerning the second issue - you are right, my observation was somewhat defocused, I have corrected it here
(5,063 Views)
CVI2013 SP2 now permits setting a breakpoint on lines with empty statements Smiley Happy
(4,283 Views)
