‎07-19-2018 03:43 PM
I use Debug Output for almost all of my debugging and the window is hidden by default and, even worse, hides itself randomly. If this happens I have to stop the program debugging instance to open the Debug Output window. Is there a setting I can change to make it stop hiding and also show by default?
I am running RT on a PXI and my program depends on a Windows-based program to run as well so it is slightly more annoying to have to restart everything.
‎07-20-2018 02:44 AM
Hello Michael,
Did you try Options>>Environment>>Bring Debug Output window to front whenever modified?
‎07-20-2018 08:42 AM
If it is constantly updating will I be able to migrate to other windows like the watch window, etc?
‎07-23-2018 02:24 AM
You can open other windows but Debug Output will still focus each time it is updated. However, Watch Window and others can be used only when execution is suspended
