LabWindows/CVI
Why doesn't CVI 7.1 compiler allow mixing declarations and statements?
I'm compiling CVI 7.1 code where I have function calls embedded in variable declarations.  How can I get C compiler to allow mixed statements and declarations?
Example:
int CVIFUNC InternationalFileDate(char filePath[], char dateString[], int bufferSize)
    time_t  time;
    VCAST_WRITE_TO_INST_FILE("001 017 001 ");
    int     error = 0;
    int     success;
    VCAST_WRITE_TO_INST_FILE("001 017 002 ");
    errChk( success = GetFileCLibTime(filePath, &time));
    VCAST_WRITE_TO_INST_FILE("001 017 003 ");
    if (success) {
        VCAST_WRITE_TO_INST_FILE("001 017 004 ");
        return InternationalDateString(time, dateString, bufferSize);
    else {
        VCAST_WRITE_TO_INST_FILE("001 017 005 ");
        return 0;
    VCAST_WRITE_TO_INST_FILE("001 017 006 ");
Error:
    VCAST_WRITE_TO_INST_FILE("001 017 007 ");
    return error;
(3,477 Views)
First: the language C doesn't permit mixing statements and declarations. This is a C++ 'enhancement'.
But this trick would do it here:
    time_t  time;
        int     error = 0;
        int     success;
        if (success) {
        else {
            return 0;
    Error:
        return error;
/* Nothing past this point should fail if the code is working as intended */
(3,464 Views)
Thanks for your suggestion.  But I have a large code base which would make this fix very labor intensive and time consuming.
Regarding mixing declarations and statements, I believe ISO C99 allowed mixing of declarations and statements to move ANSI-C closer to C++.  I was hoping to import the latest Visual C or GNU C compiler, which I believe will support mixing declarations and statements.
(3,440 Views)
C99 permits declarations anywhere within a block, not just at the head of a block before the first statement as with previous versions of C (including the native CVI C compiler).
It would be nice for NI to upgrade the native CVI C compiler to C99.  I wonder if they have any plans to do so.
As long as we're on the topic, I'd really like a realtime Java implementation (even if only compiled Java) and a native C++ compiler for CVI as well.
Real-time Java (RTSJ) is getting a lot of use these days, in everything from cellphones to unmanned aerial vehicles.
(3,425 Views)
   I'm interested too in an extension of CVI to C++ language! While I'm sceptical about Java....
(3,398 Views)
