12-07-2011 11:37 AM - edited 12-07-2011 11:39 AM
I am trying to understand how to access an SQL database from CVI.
I don't understand how the sample programs shipped with the toolkit can access the database they use if it is not listed in the ODBC Data Source Administrator.
In the code, I see the line:
hdbc = DBConnect ("DSN=CVI SQL Samples");
However, there is not an entry that I can find in the ODBC Administrator for "CVI SQL Samples."
The SQL help suggests there should be a User DSN named, "CVI32_Samples", but I don't see that entry in the ODBC Administrator on my win-7 system.
I believe the sample program is accessing a database file named, "C:\Users\Public\Documents\National Instruments\CVI\Samples\sql\samples.mdb".
Exactly how is the call to DBConnect() translated to the file, "samples.MDB", if there is no entry in the ODBC Administrator?
Mark
12-07-2011 12:11 PM
I figured it out. There is a 32 bit ODBC administrator and a 64 bit ODBC administrator. The ODBC administrator I run through the control panel is the 64 bit ODBC administrator. To access the 32 bit administrator I need to run, "C:\Windows\SysWOW64\odbcad32.exe".
I am running the samples in 32 bit mode, so I need to use the 32 bit ODBC administrator.
Best,
Mark
