LabWindows/CVI
What function is used to read Angular Position form a Task?
I have created a DAQmx task in MAX. This task configures a counter on a PCI-6259 to take the A and B counts from an encoder and give the Angular Position. What function do I use to read the value since I am no longer reading counts I am reading the position?
Thank you in advance for any advice!
John O'C
Staff Test Systems Engineer
Woodward, Inc.
Skokie, Illinois, USA
"Life is not a journey to the grave with the intention of arriving safely
in a pretty and well preserved body, but rather to skid in broadside,
thoroughly used up, totally worn out, and loudly proclaiming...
Wow...What a Ride!"
(3,724 Views)
Hello John OC,
Are you looking for a function in LabWindows/CVI which takes the place of the task in Measurement and Automation Explorer? If you are the function is the DAQmxCreateCIAngEncoderChan with more information on this page, http://zone.ni.com/reference/en-XX/help/370471W-01/daqmxcfunc/daqmxcreateciangencoderchan/.
Izzy O.
Applications Engineer
(3,708 Views)
Accepted by johnoc
Hi Izzy,
I have Created the task in MAX. The task takes input into the counter from an encoder and converts it to angular position. Do I still use the DAQmxReadCounterF64 function to read the counter? I am guessing that I do and that the function returns the angular position rather than the raw counts. Not sure though.
Thanks for taking the time to respond.
Regards-
John O'C
John O'C
Woodward, Inc.
Wow...What a Ride!"
(3,696 Views)
Accepted by johnoc
Yes.
Izundu C. Obi-onuoha
ni.com/support
(3,680 Views)
