LabWindows/CVI
What are Thread-local variables used for?
Hello everyone, maybe it's a simple question but i don't get it... usually when i do multithread application i create local variable like this
/// HIFN Document your function here.
/// HIFN You may use multiple lines for documentation.
/// HIRET Document return value here.
/// HIRET You may use multiple lines for documentation.
/// HIPAR functionData/Document parameter here.
int CVICALLBACK ThreadFunction(void *functionData)
	int MyLocalVariable = {0};
	while(quit)
		// do something
and every thread have their MyLocalVariable that can contain different value, so why NI suggest to do this?
int CVICALLBACK ThreadFunction (void *functionData);
int tlvHandle;
int gSecondaryThreadTlvVal;
int main (int argc, char *argv[])
    int functionId;
    int *tlvPtr;
    if (InitCVIRTE (0, argv, 0) == 0)
        return -1; /* out of memory */
    CmtNewThreadLocalVar (sizeof(int), NULL, NULL, NULL, &tlvHandle);
    CmtScheduleThreadPoolFunction (DEFAULT_THREAD_POOL_HANDLE, ThreadFunction, 0, &functionId);
    CmtWaitForThreadPoolFunctionCompletion (DEFAULT_THREAD_POOL_HANDLE, functionId, 0);
    CmtGetThreadLocalVar (tlvHandle, &tlvPtr);
    (*tlvPtr)++;
    // Assert that tlvPtr has been incremented only once in this thread.
    assert (*tlvPtr == gSecondaryThreadTlvVal);
    CmtDiscardThreadLocalVar (tlvHandle);
    return 0;
    int *tlvPtr;
    (*tlvPtr)++;
    gSecondaryThreadTlvVal = *tlvPtr;
    return 0;
the only advantage that I see is that also the main thread can have it's value.
maybe it's because of the limit as explained here?
"Although the Windows API provides a mechanism for creating and accessing thread-local variables, this mechanism limits the number of thread-local variables you can have in each process. The LabWindows/CVI Utility Library thread-local variable functions do not have this limitation. The following code demonstrates how to create and access a thread-local variable that holds an integer."
How much is the Windows API limit?
Davide Vittorio G. - TLGB S.R.L.
Italian SW Developer
(2,468 Views)
Accepted by holly7787
Hi Holly,
I'll start by saying there are 2 other more standard ways to define thread-local variables:
static __thread char TimeStr[80]="";
and
 thread_local static char TimeStr[80]="";
Depending on you C99/C11 compiler.
Yes, declaring a normal variable inside a function will make it local to each thread, but what if you need it static ? For instance to remember a value between calls, or to return a string ? You can do this very simply with thread local variables without complex semaphore logic. The drawback is that you cannot share the values between the threads, but then you use a normal static for that.
(2,464 Views)
Actually you hit the only problem that i have, and I didn't think that I can solve with this.
I have a function that i want to return a string, i have to create always a char array variable and pass it as a parameter to get it returned.
(2,462 Views)
Si, e facile fare cosi:
char* SomeFunc(int arg) {
return TimeStr;
It works well for many things... but you can't use it for this, it'll fail:
printf("%s %s", SomeFunc(1), SomeFunc(10));
(2,449 Views)
