LabWindows/CVI
VI_ERROR_LIBRARY_NFOUND
hi..
i am trying to use the viopenDefaultRM() function and trying to initialize
the instrument via the CVI driver written for our instrument.. the status
returned is VI status = VI_ERROR_LIBRARY_NFOUND( A code library reuqired
by VISa could not be located or loaded)
can anybody help me what is the reason for this error..
(9,133 Views)
Karthik:
If you get this error on viOpenDefaultRM, it probably means that VISA
isn't installed properly. If you have CVI on your machine, that's a
surprise to me since CVI installs VISA unless you de-select it. You
can get NI-VISA from our ftp site at:
ftp.ni.com/support/visa/drivers
When this error is returned from viOpen (which you say is not
happening) then it usually means that a lower-level driver such as NI-
488 is not installed.
Dan Mondrik
Senior Software Engineer, VISA
Sent via Deja.com http://www.deja.com/
Before you buy.
(9,133 Views)
How can we automatically install visa in the distribution kit ?
(9,133 Views)
It should be included by default in the download of CVI either from here (http://www.ni.com/lwcvi/download/) or your company's software repository.
(7,063 Views)
Hi AChalana,
thanks for your contribution but a lof of water has passed under the bridge in the 16 years since this discussion started Smiley Surprised, I suppose Pierre has already found his answer Smiley Wink
(7,053 Views)
