LabWindows/CVI
Using thread safety variable
Hello ,
My coding is as this :
DefineThreadSafeScalarVar(struct dTagPack ,dGlobel,0);
struct dTagPack *dGlobel = NULL;
int main (...)
int CVICALLBACK Mycallback (int panel, int control, int event,void *callbackData, int eventData1, int eventData2)
struct dTagPack *root;
struct dTagPack rr;
dGlobel = ExportLink() ;//get a link from a dll file
InitializedGlobel();
root = GetPointerTodGlobel();
rr = root[0];
ReleasePointerTodGlobel();
UninitiallizedGlobel();
return 0;
When view the value of variable rr , its elements are all equal zero , but check variable of dGlobel , its value is correct . I am not sure if the TSV would modify the value .
David
(3,059 Views)
David,
I don't see how the TSV would change the value of rr here. But it depends on what you do in GetPointerTodGlobel(). There is a good document on TSV that you can find in:
http://zone.ni.com/devzone/conceptd.nsf/webmain/2DF76D8073AA2A8C86256D2C005586D2?opendocument#4
It contains a good example for TSV, but again I don't see how rr will be modified here.
Hope that helps.
Juan Carlos
N.I.
(3,059 Views)
