LabWindows/CVI
Using Twain drivers with CVI
I need to interface a scanner with my software written with CVI. How I can do it ? It's possible to use twain drivers ? Please, help me !
(3,194 Views)
Hello
CVI does not have any built in drivers for twain drivers. However, if you can find a C driver or an activex control for twain, you can use CVI 5.5 and above with the activex control. CVI will generate wrapper functions and the appropriate libraries so that you can start using the functions directly.
Just a couple of ideas. I hope this helps
Bilal Durrani
NI
Bilal Durrani
NI
(3,194 Views)
