LabWindows/CVI
Using SQL database
Hello
I want to know if I can use the free SQL database under labwindows
Message 1 of 10
(4,075 Views)
Which "Free" SQL database? There are several.
The answer is Yes. I suggest you look at the CVI documentation, and do a search for "SQL" on the Labwindows/CVI board.
Message 2 of 10
(4,044 Views)
I would to use SQLite using labwindows cvi
Message 3 of 10
(4,035 Views)
Searching for SQLite on the Labwindows/CVI board gives 11 hits. I suggest you start there.
Message 4 of 10
(4,017 Views)
Hello I did not understand where i found it because i seach for example on cvi folder i found samples but it requires the SQL Toolkit I do not have
thks for help
Message 5 of 10
(4,014 Views)
Which version of CVI are you using? Starting from CVI 2013SP2, the license for CVI full development system edition covers also the SQL toolkit, which you can install and use.
Message 6 of 10
(4,002 Views)
I'm using the  LABWINDOWS/CVI BASE 2017 , so im not allowed to use the exemples developping with  SQL Tolkit
Best regard
Message 7 of 10
(3,990 Views)
I found this toturiel and it's very helpful  "https://www.40tude.fr/blog/sqlite-et-cvi/"
it's allow to créate table , now  I want to save images in this database  that  is possible!! if yes how i can precess  or i have to convert the image under a specific type to store them
thank you for your helping
Message 8 of 10
(3,985 Views)
Hello Bylka,
I believe this forum can answer your question :
https://forums.ni.com/t5/LabWindows-CVI/How-to-save-a-picture-bmp-or-jpg-to-database-Access-or-SQL/t...
Junior
Message 9 of 10
(3,976 Views)
Hello Junior,
Thanks for help i will read it
Message 10 of 10
(3,945 Views)
