03-15-2007 03:27 PM
03-16-2007 12:59 PM - edited 03-16-2007 12:59 PM
Hi Liz,
Currently the LabWindows/CVI Run-Time Module for Linux does not have support
for Network Variables. The Run-Time Module for Linux is essentially a way
for users to compile their LabWindows/CVI applications on Linux. So you will
write your code on Windows and then re-compile it on Linux once you know
everything works.
As far as what’s supported, there are several resources you can use to get a
list. These resources are the Differences in
LabWindows/CVI between Windows and Linux LabWindows/CVI Help topic, and
the Introduction
to the LabWindows/CVI Run-Time Module for Linux tutorial. Also for
some additional information, check out the NI LabWindows/CVI Run-Time
Module for Linux homepage.
What I would suggest is to submit a product suggestion
and let us know what your application, what its needs are, what libraries
you would like to see supported that are currently not.
Best Regards,
Message Edited by Jonathan N on 03-16-2007 01:00 PM
03-16-2007 01:52 PM
03-16-2007 05:28 PM
