LabWindows/CVI
Using GetCtrlMenuAttribute(.....)
Hi ,
i'm trying to use GetCtrlMenuAttribute , i want to see if a menu item is checked and this is my simple func
void CVICALLBACK SetLangHeb (int menuBar, int menuItem, void *callbackData,int panel)
  int check = -1;
  int status;
  status = GetCtrlMenuAttribute (panel, menuBar, menuItem, ATTR_CHECKED, &check);
  if ( check == 0)
  printf("checked");
but it doesn't work..... am i doing something wrong ?
Kobi Kalif
Software Engineer
(4,670 Views)
1) I would assume the opposite behavior:
Description:  Specifies whether a menu item has a checkmark.
0 = Does not have check mark
1 = Has check mark
2) What do you mean by 'does not work'? You can use the debug mode, set a breakpoint and check the value of a variable, including status.
Wolfgang
(4,667 Views)
As far as I can see you only need to reverse the logic of your code:
  if ( check != 0)  {
         printf("checked");
Please remember that this command gets attributes of menus owned by specific controls (e.g. a table): not all controls can own a menu. To retrieve attributes of normal menu on a panel you must use GetMenuBarAttribute.
(4,666 Views)
Dont mind the
if ( check != 0)  {
         printf("checked");
my problem is that my function returns -139.....
the function fails...it doesn't update my check var....
Kobi Kalif
Software Engineer
(4,662 Views)
Accepted by Kobi_K
If you use the help available with CVI you can read:
-139 UIECtrlDoesNotHaveMenu Controls of the type passed do not have a menu.
that's exactly the earlier comment of Roberto...
(4,659 Views)
