LabWindows/CVI
Using ChangeDetectionEvent with NI USB-6259
i am very new to labview and LabWindows, so this might be very trivial to solve.
I would like to perform an action ( change some UI element ) when ever I receive a rising edge from a TTL signal.
I hoped to achieve this by following the ReadDigChan-ChangeDetectionEvent example, and defining a DAQmxRegisterSignalEvent() for rising edge on one of the Digital input lines, but I even fail to use the example for my
USB-6259 (BNC).
When I try to perform a Change detection on any of the lines of port 1 and 2 I get
Lines specified do not support change detection.  Select lines that support change detection. Device: Dev1 Physical Channel: port1/line0  Task Name: _unnamedTask<0>  Status Code: -201020
Do I missunderstand something? Should the Digital In ports on the 6259 support change detection?
When trying the same with port0 the application freezes for a long time and than just throws out a message saying that
DAQmxReadDigitalLines() timedout.
I hope that is enough information to answer the question. If not what else do you need?
thank you,
Manuel
(5,057 Views)
Accepted by topic author PasiekaM
it seems the USB-6259 does not support change detection.
Link:
Digital Change Detection in NI-DAQmx
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000PAn9SAG&l=en-US
(5,044 Views)
Hello DanielMorris,
hmm, that I would not have expected. Following the error message it might make sense, but the NI documentation you linked is kinda vague to me.
In addition I saw that using the NI MAX tool and looking at the Device Routes there is a "Direct Route" between the ChangeDetectionEvent and the different PFI0-16 lines. ( dont know if this is of importance, though )
Well my work around is to use a counter to performe edge counting, and a timer and polls the counter value.
Thank you!
(5,038 Views)
