09-12-2014 02:30 PM
I am using CVI 2013. I have seen the following behavior on a couple of different projects. If I make changes to the user interface and build the project, the UI changes don't show up. If I rebuild (i.e., select rebuild from the build menu) the project, however, the user interface is updated correctly. This is a nuisance I can work around, but it doesn't seem to be the correct behavior.
09-13-2014
01:55 AM
- last edited on
11-18-2024
04:48 PM
by
Content Cleaner
Which exact version are you using? Also, are you using embedded UIRs? Similar behaviour has already been reported a couple of times (e.g. here) and should have been corrected in Service Pack 1: see Bug Fix Information document for that version here, ID #433769.
09-15-2014 01:21 PM
Thanks for the info. Yes, I have the "Embed .UIRs" button checked. I am running version 13.0.0 (647). I'm assuming that the patch to fix this problem hasn't been installed yet.
09-16-2014 07:35 AM
