LabWindows/CVI
Use COM from LabWindows CVI gives "Operation not available" error
Dear all,
I'm trying to use a third party DCOM server from my LabWindows/CVI. This would allow me to control remotely the software.
The software abobe and my application are both running on the same machine, for the moment at least.
I've installed and activated DCOM on the PC.
To get the hande to the remote interface I've used the following API CA_GetActiveObjectByClassIdEx(...).
The clsid and appid have been obtained by looking in the registry and via dcomcnfg.exe respectively.
Currently I'm always getting  the error value -2147221021 which translates on the "Operation not available" error message (returned by CA_DisplayErrorInfo(...)), and unless I'm mistaken it doesn't even match with the codes listed in ActiveX Library Error Codes help page.
Do you guys have any hints for me on the topic?
Thanks in advance
All the best
(2,863 Views)
According to this forum post from a few years ago, it seems like this error will pop up if the server is already in use for another operation, which sounds like it might be happening from the way you described the software setup for your application since everything is running on the same computer.
"-2147221021 Operation not available" https://forums.ni.com/t5/LabWindows-CVI/2147221021-Operation-Unavailable/td-p/1922841
Applications Engineering
(2,834 Views)
Accepted by topic author TheKid77
Hi Daniel,
thanks for your reply.
I solved my problem by creating an instrument driver for my ActiveX server  ( Tools >> Create ActiveX Controller...).
So far it is working properly.
Best Regards
Francesco
(2,829 Views)
Glad to hear it! Feel free to mark your last post as the solution so other users can more easily find the answer to this issue in the future.
(2,821 Views)
