LabWindows/CVI
Unrecoverable Internal Error at 001B:102E2E10
When I compile/link, I get the follwowing error message: "Unrecoverable Internal Error at 001B:102E2E10. LabWindows/CVI will be aborted" Appears to compile OK, but before linking, get the above error message in a dialog box.
(2,945 Views)
Does this happens with any project that you compile? or is this specific to a project? One good place to start is to make sure that the installation does not have any problems; go to add/remove programs, select CVI, select change and go through the repair option. This makes sure that all the files are in place and properly registered.
The next thing to try is to open up some of the examples and compile them; after the repair there should not be any problems.
Plese give this a try and let me know how this goes.
Juan Carlos
N.I.
(2,945 Views)
