LabWindows/CVI
Undefined symbol '_Timeout_Config
If it helps here is the easyio.h
Message 11 of 13
(1,162 Views)
I think I found the problem,
I don't think it was finding the correct libraries I added easyio.lib, and dataacq.lib to the build manually and it compiles with no errors. I'll check it with the actual device to see if it works completely.
Thanks again for your help Roberto,
Michael Eller
Message 12 of 13
(1,158 Views)
Accepted by topic author meller
That's exactly why I suppose there is something wrong in your installation: not sure about easyio.dll, but you should not need to add dataacq.lib to your project, the system should be able to find system libraries by itself. Anyway I'm happy you succeeded in solving your problems.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
Message 13 of 13
(1,151 Views)
