LabWindows/CVI
Unable to find USB-8451 from LabWindows/CVI
The 8451 is visible in MAX, but when trying to find it from LabWindows code (ni845xFindDevices) i get the error code -301701 : "NI-845x: The resource name contains insufficient location information, describes a resource that is not present in the system, or describes a resource that may be in use by a separate process"
- LabWindows 2020
- NI-845x 21.3
-Win 10 Enterprise (64 bit)
(572 Views)
Could it be that you actually have opened it in NI Max? For the test panel or similar for instance?
The last part of the error message mentions that possibility, so it doesn’t have to be the first part, that he can’t find it at all.
Rolf Kalbermatter  My Blog
(546 Views)
Thank you for the response, I'm quite sure that is not the issue.  BTW upgraded the software for the 845x to version  2022-Q3 with no change in behavior.
(535 Views)
It was just an idea. Since NI Max can see the device, it is HIGHLY unlikely (pretty much impossible) that the first and second possible reason in the error message, of the library not finding the device, is the actual reason for this error. Leaves the third part of the error explanation as most likely option.
(529 Views)
