LabWindows/CVI
UI to Code Converter generating code with errors.
Running the UI to Code Converter on my uir file generates source code which fails to compile. A sample stretch of code is...
    errChk(SetCtrlAttribute (hPanel, GUI_STRIPCHART, ATTR_XLABEL_FONT, "Arial"));
    errChk(SetCtrlAttribute (hPanel, GUI_STRIPCHART, ATTR_YLABEL_FONT, "Arial"));
    errChk(SetCtrlAttribute (hPanel, GUI_STRIPCHART, ATTR_YLABEL_FONT (RIGHT), "Arial"));
...the third line is the one which fails with the error...
  2385, 88   Found 'int' expected a function.
  2385, 5   Undeclared identifier 'RIGHT'.
  2385, 5   Type error in argument 3 to `SetCtrlAttribute'; found 'void' expected 'int'.
As should be apparent the third line is essentially trying to do the same thing as the second line (which is correct) for a "right" y axis (which I am not using). Is this a reported bug? Has this been fixed in a newer version of CVI?
It is easy to fix (by commenting out the offending lines) but I thought I should report the issue...
Trevor
(3,571 Views)
What version of CVI are you using? I just tried this with 8.5 and it seems to have been fixed.
(3,543 Views)
HI Trevor,
This was actually fixed in CVI 8.5.1 (the bug ID is 68468, although it's not completely clear from the title that it also fixes this issue).
- Luis
(3,535 Views)
