LabWindows/CVI
LabWindows CVI 6.0 and Fetching Data from Oracle
I need help Fetching data from an Oracle Database.  Originally my code was Fetching data from a MySQL database.  We are migrating from MySQL to Oracle.  My code works for the MySQL database and for the most part works for the Oracle database.  The only problem I have when running the Oracle database, it seems the database application hangs when attempting to close the application.  The CPU useage spikes up to 50%.  The application will not close on it's own an you have to use Task Manager to close the application.  I susptect the application is hanging at the Fetch loop.
Please find attached my code.  Please excuse the "test code".   I have also included the tnsnames.ora file for my setup.
(3,450 Views)
I just wanted to post to let other customers know what we already talked about on the phone, which is that this is a known issue with the CVI SQL Toolkit that was corrected in version 2.1.
I believe you are downloading the latest versions of CVI and the SQL toolkit, please let me know by phone, email, or forum how that goes.
With warm regards,
David D.
(3,426 Views)
