LabWindows/CVI
Trouble compiling in "release64/debug64" configuration
A few months back I wrote a code in LabWindows/CVI to generate a DLL that then I open with Matlab. I had 32-bit version as my OS. Everything was OK I was happy with it. Recently I had to switch to 64-bit OS because of physical memory problems. I updated Matlab to 64-bit and I installed a more recent version of LabVIEW (togerther with LabWindows/CVI) 2013 Fall release, which is still 32-bit.
Now in this configuration, I cannot generate the DLL from my LabWindows/CVI code. I am using the "release64" (or "debug64") modality but I get this error message "Library Load Error": the list of errors include for example "Cannot find 64-bit program file for library 'NIIMAQdx'." and many others together with this one. In my code I am actually using this library (NI-IMAQdx) in fact I cannot compile the code.
What can I do? Is it just a problem of 64-bit version libraries? Is there a way to have support for 64-bit version libraries? How can I create my DLL if there is no support for such libraries in the 64-bit version OS? Is the latest version of LabWindows/CVI based on 32-bit or 64-bit processor? Does this make any difference?
In advance, thanks very much,
Nicolino
(5,757 Views)
Which version of  NI-DAQMX did you install ?
http://www.ni.com/white-paper/6910/en/ says:
NI-DAQmx added support for 64-bit user mode in NI-DAQmx 8.9 (ANSI C) and NI-DAQmx 8.9.5 (ANSI C, LabVIEW 2009, and .NET Framework 3.5). This now allows for 64-bit application development on 64-bit operating systems when developing in a 64-bit Application Development Environment (ADE).
(5,737 Views)
In this file "C:\Program Files (x86)\National Instruments\NI-DAQ\readme.html" I found that the version of NI-DAQmx I have installed is 9.7.5. Do you think this version is not suitale for my problem?
Sorry for my silly questions, I am quite new with LabVIEW products: how are NI-DAQmx and NI-IMAQdx library related? And also, I have installed the LabVIEW package (including LabWindows/CVI) in 32-bit version... Can this be a probelm? Should I install the 64-bit version or this is not related to the version of certain libraries which I need (such as NI-IMAQdx and NI-vision)?
Thanks a lot again,
Nicolino
(5,726 Views)
Sorry thats my fault . I read NIDAQMX instead of NIIMAQMX
(5,722 Views)
Hi there,
Looking at this helpfile, you'll need to install the 64-bit version support of your NI software to get this DLL to work in a 64-bit environment: http://zone.ni.com/reference/en-XX/help/370051V-01/cvi/programmerref/creating_dlls/
"Note  You can load 32- and 64-bit DLLs only into processes with the same bitness. For example, you can load a 32-bit DLL into a 32-bit process. You cannot load a 32-bit DLL into a 64-bit process, and vice versa."
I believeNI-IMAQdx 3.7 has 64-bit support and NI-IMAQ 4.5 and up has support for 64-bit. CVI 2012 is 64-bit compatible too.
I hope this information helps
(5,712 Views)
Thanks for the answer... I downloaded and installed the latest verison on LabVIEW and LabWindows/CVI for 64-bit version OS, together with the latest drivers. So I now have the latest NI-IMAQdx drivers. But still I have exactly the same problem with creating my DLL: "Library Load Error" is always there for exactly the same libraries. In particular, I am using NI-IMAQdx and NI-vision, which apparently are not supported for 64-bit version.
From another forum, I found the 64-bit version for NIIMAQdx.lib and with this "unsupported" version of the library I solved part of my problems. Still, I have not found a NIvision.lib library 64-bit version available on line.
Do you know if there is a version available (even if not supported)? Can I replace that with something similar (even if that would mean to change my code)?
Thanks very much,
Nicolino
(5,690 Views)
Hello again,
Does anyone have any news about NI support for NI-vision library for 64-bit version OS? I am really stuck with the creation of this DLL using LabWindows/CVI and I really struggle to move on...
Many thanks,
Nicolino
(5,659 Views)
