11-12-2003 05:06 PM
11-13-2003 05:35 AM
11-05-2006 07:16 AM
11-06-2006
03:21 PM
- last edited on
01-05-2026
09:30 AM
by
Content Cleaner
Hello Kumar,
There is a shipped example to perform this. You can find it on the Example Finder browsing "Hardware Input and Output » DAQmx » Analog Measurements » Voltage" and the name is Acq&Graph Voltage -Int Clk-Analog Start w Hyst.
If you look for specific triggering method, this document can give you much more ideas: Tips and Techniques in Data Acquisition Triggering - NI-DAQmx
This is part of new online documentation on DAQmx, from easy task to the more advance features used in several programming languages.
Hope this helps,
