LabWindows/CVI
Triggered Acquisition
I have a PCI 6014 and I am using LabWindows/CVI. I want to start acquiring data when an analog input crosses a threshold voltage, then stop when it crosses a different threshold. I'm not sure where to begin.
(3,338 Views)
Unfortunately your card doesn't integrate hardware analog triggering facilities, so you must use software analog triggering.
I suggest you to begin studying an example that ships with CVI: the example is ai_async.prj and is located into \samples\easyio directory. This examples shows you an example of how to start an acquisition with sowtware analog triggering.
Hope this helps.
Roberto
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
(3,339 Views)
Hi Roberto,
I am using PCI 6221 DAQ Card. I want use the analog trigger in this. I know This card does not have the Hardware analog trigger. But I beleive I can use Software analog trigger.
In year 2000 I have done with PCI 6023E card.  I don't know how to do it in M series card.
Hope you can help me out.
Reagrds,
Kumar.E
(3,204 Views)
Hello Kumar,
There is a shipped example to perform this. You can find it on the Example Finder browsing "Hardware Input and Output » DAQmx » Analog Measurements » Voltage" and the name is Acq&Graph Voltage -Int Clk-Analog Start w Hyst.
If you look for specific triggering method, this document can give you much more ideas: Tips and Techniques in Data Acquisition Triggering - NI-DAQmx
This is part of new online documentation on DAQmx, from easy task to the more advance features used in several programming languages.
Hope this helps,
Gerardo O.
RF SW Engineering R&D
(3,179 Views)
