LabWindows/CVI
Toggle button initially dimmed
I have a question on how to do it. Initially my toggle button is dimmed and when I received a signal from PLC my toggle button must be active or undimmed.
Thanks in advanced.
(4,578 Views)
Use SetInputMode to dim or undim a control
(4,549 Views)
or, in the UI editor, change the setting of the checkbox ;Initially dimmed'
(4,534 Views)
Actually I set-up the button like that what I want to know is If I received a input signal from PLC the button should be dimmed or unclickable.
int CVICALLBACK Standard (int panel, int control, int event,
  void *callbackData, int eventData1, int eventData2)
 switch (event)
  case EVENT_COMMIT:
   GetBitFestoInputs /* if I received signal from PLC (true) the button below would dimmed*/
   /* Dim the STD button and activate the PREM button */
   SetCtrlAttribute (panelHandle, PANEL_STD, ATTR_DIMMED, 1);
   SetCtrlAttribute (panelHandle, PANEL_PREM, ATTR_DIMMED, 0);
   break;
 return 0;
(4,465 Views)
Accepted by Master_Viper
Yes, that should work. Do you have any problem with that?
(4,456 Views)
Thanks it works.
(4,449 Views)
