LabWindows/CVI
取消
显示结果
搜索替代
您的意思是:
The file must exist
I use LabWindows2010 and I don't know very well use. After extensive research on the forum and in using the software, I can not find the solution to my problem. When I generate the *.exe of my project, an error message appears:
exec_EXEC Fatal Error
The file must exist
I can not find where the problem
Thank you for your help
Best regards
DiaDia64
0 项奖励
1 条消息(共 7 条)
3,717 次查看
Does it happen with all the projects ? or just one ?
One more thing , Does it happen with Examples also ?
Kobi Kalif
Software Engineer
0 项奖励
2 条消息(共 7 条)
3,693 次查看
Thanks for your help,
It happen with just this project. This does not occur with example.
I have additional information :
In the tab  "Instruments" => "TECHNITEST EXECUTE LIBRARY" => "Utilities for files" => "exec_Read_ini" =>
The file name placed in "Path" does not exist.
Could this cause my problem? And if so, how to fix it?
Best Regards
DiaDia64
0 项奖励
3 条消息(共 7 条)
3,674 次查看
1. if i'm not mistaken , you are trying to read from an ini file , in that case you need to make sure that the file you trying to read exits in the currect library.
2. i didn't understand if the error is in the compilation process or it's a bug in the software
    if it's a bug you can debug it using a break point and see exacly which function is makeing the bug , look for it in the Debug menu.
Kobi Kalif
Software Engineer
0 项奖励
4 条消息(共 7 条)
3,658 次查看
Thanks lot for your help
1) Actually, I just read this. Ini file but it does not exist on my PC that I am puzzled. Apparently this file does not exist in the library.
I would have checked it before I use library to continue.
2) I am already in debug mode and I have a non-fatal error that is not related to the error of this post. Maybe I'm wrong. I put you in the event that the only mistake I found in debug in PJ.
I still look in my direction.
Best Regards
DiaDia64
下载全部
0 项奖励
5 条消息(共 7 条)
3,645 次查看
Hello DiaDia64,
the error you are receiving means that you are using a string before it is initialized any way. That is, your 'lpszCmdLine' string can contain any garbage. Inizializing it before calling your function will solve the error. At the minimum, use strcpy (lpsxCmdLine, ""); before the call to exec_start ().
Regarding reading the INI file, every file I/O function returns an error in case the file does not exist: you may want to check the file exists before trying to access it using FileExists () function form the Programmer's Toolbox or GetFileSize () from the Utility library or simply trapping the error returned from the function and warning the user of the problem.
0 项奖励
6 条消息(共 7 条)
3,636 次查看
Your help is precious to me
I'll watch what you tell me and I would then return.
I'll change my code to verify that the error disappear. Then for my main mistake, I will eesayer to do as you please tell me and find a solution. If I can not, I would also return.
Thank you again
Best Regards
DiaDia64
0 项奖励
7 条消息(共 7 条)
3,632 次查看
