LabWindows/CVI
Text Message with indice letters
Dear all,
With Labwindows CVI, I would like to write a text which contains indices.
I would like to write  for example Ipkpk, where pkpk is written as an indice, like the first text message in the attached image(or like the code I_{pkpk} of Latex).
Thank you so much for any help.
(4,859 Views)
1. This is possible, but not very elegant: You have to use separate texts, and for each text you can define its size and position.
2. You can also support the suggestion in the CVI idea exchange to support subscript and superscript...
(4,854 Views)
I have alredy tried this solution but as you said, it is not elegant. I open a suggestion for this topic.
Thank you.
(4,848 Views)
