LabWindows/CVI
Tab Attribute required
Hi all,
Is there any tab attribute present in CVI by using of which disables or Dimmed all the controls present on that tab?
Can ATTR_DIMMED disables all the controls present on that tab?
mhs100
(3,456 Views)
you can dim the tab panel itself using SetPanelAttribute.
(3,454 Views)
How?
I mean how can i be specific to only Tab 2?
(3,451 Views)
Accepted by mhs100
ah... before you can access any tab panel, you need to use
GetPanelHandleFromTabPage ( panel_handle, PANEL_TAB, 1, &tabpanel_2_handle );
for every tab panel. This will give you the panel handle tabpanel_2_handle for the tab panel PANEL_TAB which you can use to set attributes of this panel using SetPanelAttribute ( tabpanel_2_handle, ATTR_DIMMED, 1 );
int GetPanelHandleFromTabPage (int panelHandle, int controlID, int index, int **tabPanelHandle);
Purpose
Retrieves the panel handle of a tab page in a tab control.
Use the panel handle to specify the panel associated with the tab page in subsequent function calls.
(3,448 Views)
You can use
SetTabPageAttribute (ATTR_DIMMED)
(3,423 Views)
