LabWindows/CVI
String control frame thickness
Is it possible to change the frame thickness of the string control?
I want to display a string without the recessed frame.
Thanks.
(3,414 Views)
Sure.
You can paint it in transparent in the UIR editor or you can modify it programmatically with the ATTR_FRAME_COLOR attribute of the string control.
(3,414 Views)
There's only one caveat: you can change the frame color of a classic-style string (CTRL_STRING) but you cannot change the frame color of a lab-style string (CTRL_STRING_LS). But since the goal here is to hide the frame, and those two control styles only differ in their frame, there's no reason not to use the classic-style string.
Luis
NI
(3,414 Views)
Hi everyone,
You can also use a simple "text message" (next to the text box in the menu) instead of a text box and change the background color to the one you need. You'll have no frame at all.
Juan Carlos
N.I.
(3,414 Views)
