LabWindows/CVI
Showing results forĀ
Search instead forĀ
Did you mean:Ā
Sorting list problems in 2013
I'm programming by CVI.
However, I encounter a critical problem - the list sort built-in library does not work.
In both of console and real-time application, the sort result is wrong.
How can I solve this problem.
int main (int argc, char *argv[])
 double value1 = 3.0;
 double value2 = 4.0;
 double value3 = 1.0;
 double value4 = 2.0;
 double test;
 int i;
 ListType newList;
// if (argc < 2 || argc > 3)
//  usage (argv[0]);
 printf("This is built-in List type test program!\n");
 newList = ListCreate(sizeof(double));
 if (newList == VI_NULL)
  return -1;
 ListInsertItem(newList, &value1, END_OF_LIST);
 ListInsertItem(newList, &value2, END_OF_LIST);
 ListInsertItem(newList, &value3, END_OF_LIST);
 ListInsertItem(newList, &value4, END_OF_LIST);
 printf(">>>>> The original list\n");
 for (i=0; i<ListNumItems(newList); i++)
  ListGetItem(newList, &test, i);
  printf("[%d] %f\n", i, test);
 ListInsertionSort(newList, DoubleCompare);
 printf(">>>>> The sorted list\n");
 if (newList)
  ListDispose(newList);
 return 0;
>>>>> The original list
[0] 2.000000
[1] 3.000000
[2] 4.000000
[3] 1.000000
>>>>> The sorted list
[0] 4.000000
[1] 1.000000
[2] 2.000000
[3] 3.000000
Message 1 of 8
(6,556 Views)
ListInsertItem function is not correctly working, too.
Who's duty about modification of this wrong library?
Message 2 of 8
(6,544 Views)
There is nothing wrong in those function, it's really that you haven't read the help for ListGetItem, which clearly states that positionOfItemToGet parameter must vary from 1 to the number of items in the list. With your for loops starting at 0, you are really reading the last element in the list first (END_OF_LIST has the value of 0), next all other elements except the last one.
Proud to use LW/CVI from 3.1 on.
My contributions to the Developer Community
________________________________________
If I have helped you, why not giving me a kudos?
Message 3 of 8
(6,537 Views)
Thanks for your attention.
I just know about the index.
Message 4 of 8
(6,531 Views)
I met the same problem with ListFindItem:
ListFindIt​em with StartingPo​sition out of range
You are not alone Smiley Wink
Most CVI functions returned error codes except the List functions, most CVI functions are 0 based except the List functions. The List functions don't respect the CVI "rules", unfortunatly for us !
Best regards.
Message 5 of 8
(6,488 Views)
Well, as Daniel and Luis explained in the thread you linked, this is not actually a bug, even though I agree that it's not obvious.
Neither it's true that list functions are the only 1-based ones: just as an example, when you work with tables, row and column indexes are 1-based, working with a database the first record is 1 and there may be other cases.
The true fact is that when you use a function that requires an index you must double-check whether it is 1-based or 0-based.
Message 6 of 8
(6,482 Views)
Hello Roberto,
I agree with you, it's not a bug and we must be careful when using index.
1°) I think the documentation is "ambiguous". The parameter startingPosition for ListFindItem function is defined like this:
The position of the item in the list to start the search from. The position may be a number from 1 to the number of items in the list.
To start searching from the first item in a list, the constant FRONT_OF_LIST may be passed.
When you read " The position may be a number from 1 to the number of items in the list"  you mind automatically eliminates values <1 (you never remember that FRONT_OF_LIST = -1 ! ) and END_OF_LIST is not mentionned.
If you write the help like below with the possible values, perhaps there will be less confusion:
The position of the item in the list to start the search from. The possible values are:
  • -1 (FRONT_OF_LIST) to start searching from the first item in a list.
  • 0 (END_OF_LIST) to start searching from the last item in a list.
  • a number between 1 and the number of items in the list.
2°) I think it's was a bad idea to define END_OF_LIST = 0 because 0 is a "special" value.
END_OF_LIST = -2 would have been a better choice. So ListGetXXX would return NULL with an index = 0 and the index mistake would  be easier to detect .
Bye.
Message 7 of 8
(6,468 Views)
Yes, you're right, that choice of constant value is odd and may lead to confusion, even more if you consider for example that VAL_TO_EDGE (the constant used to set Rect structures up to the end of valid range in tables) is defined as -1!
That note of passing FRONT_OF_LIST to start searching from the beginning is too weak compared to END_OF_LIST being set as 0, so I agree that an improvement in the function help may be needed.
I have as a golden rule to carefully read the help and use system-defined constant whenever possible: this example encourages me to continue this way! Smiley Wink
Message 8 of 8
(6,459 Views)
