LabWindows/CVI
Simple frequency acquisition
I'm trying to acquire a sine wave from my com1 via rs232. I don't have a DAQ, and that's where it's causing problems. I have a sine wave of around 200 hz going through an rs 232 cable into my computer. The frequency will shift between 0 and 200 hz. I pretty much have tried looking everywhere but all of the solutions seem more complicated than they should be. I'm using LabVIEW 8.2.1.
I will upload my VI so you can see. In the end, I want to replace the "simulate sine wave" with the acutal sine wave coming from the RS232. It's an analog sine wave.
(3,061 Views)
You have posted your question on the LabWindows board; there are a lot more LabView specialists on the LabView board, so I suggest you post your question there instead. Good luck...
JR
(3,053 Views)
