10-02-2013 03:25 PM
I have just purchased a DYMO LabelWriter 450 to print name badges. DYMO has an SDK, but it doesn't support ANSI 'C'. I can print to it using PrintTextBuffer, but the margins are very large reducing my print area. Is there any way to reduce the margins?
10-03-2013 12:42 PM
Hi jrbecker,
PrintTextBuffer just sends whatever’s in the text buffer (characters stored as bits) to a printer or file. You can’t specify any sort of formatting for it, like text size or margins. I don’t think there’s going to be a way to do that just in ANSI C without interacting with the device’s API. Those things will be controlled by functions specific to the device that are probably contained in the SDK.
Kelsey Johnson
Applications Engineer
10-03-2013 01:10 PM
kelsey,
I took care of my formatting issues by writing everything to a panel with diffent fonts and sizes and then doing a PrintPanel. I'm just left with a 0.3 inch margin which is too much for a 1.2" label. I'll try to find a DYMO SDK expert and see if they can write me a small exe that sets the margins to zero.
10-08-2013 02:06 AM
Thank you for the observation, we are going to take into account.
Just to make sure you know: DYMO has a blog for developers, developers.dymo.com, where there is quite a lot of useful information on configuring LabelWriters.
10-09-2013 04:52 PM
DYMOsupport,
I checked the BLOG and could not find anything that would help me. It would be nice, for those of us that can't use the SDK, if DYMO had a command line executable that took parameters to allow users to set some of the more commonly used printer parameters. That way we could call it from our code.
10-15-2013 06:37 PM
Hello jrbecker,
Have you tried creating a .NET Controller in LabWindows/CVI? You can access this feature by selecting Tools»Create .NET Controller. This will allow you to choose a .NET assembly and create a LabWindows/CVI wrapper automatically. The help document for this feature can be found here: Create LabWindows/CVI .NET Controller Dialog Box.
I installed the SDK for DYMO as a test, and it seems to install a .NET assembly in its <dotNET Samples> directory. The DLL is called Interop.Dymo.dll.
Once you create the .NET Controller, you can call into the SDK from LabWindows/CVI.
I hope this helps,
